Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 149
Thread: think i may have finally cured the famous flat spot hesitation,read on....
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default think i may have finally cured the famous flat spot hesitation,read on....
    i havnt got a clue to upload pics so il have to try and explain best i can feel free to ask any questions,
    its to do with the boost control solenoid(bcs) on the slam panel, what i did first was with a hacksaw cut the small thin metal band holding the black body to the dirty creamish bottom that the vac pipes attatch to, pulled them apart and inside is an orange rubber seal attatched to a pin that goes up into the body, im no expert but to me its the same sort of thing (electro magnet i think) as the egr valve just on a smaller scale, i pulled the pin out and that seemed pretty clean, sat behind where the orange rubber seal was is a small round plastic filter thing, removed and cleaned that as it was black, i cleaned everything lubed the pin and refitted, now on the outside of the bcs is a square looking piece attatched (this bit i done is where i think made the difference) you can remove the outer casing with a small screw driver and inside that is another small square little filter type part which was also gummed up and black, this part is where the vac gets blead from, i started to clean it and because i have a spare bcs thought **** it left it off along with the cover piece and thought id try it on the car like that, i just took the car out and had no flat spot and/or hesitation on acceleration, the boost seemed to come in smoother rather than a lump, ive only took the car for a quick blip about 5 miles or so, so to say for definate i would have to do more, but im quietly confident.
    my theory now goes that the little filter type thing in the square piece attatched to the bcs was gummed up not letting the vac blead off quick enough when you demanded power with your right foot, hopefully some of you guys who suffer with the famous flat spot/hesitation will try it to confirm hope this helps any feed back welcome
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    a good right up there
    i have read many threads on this including this one
    http://www.vectra-c.com/forum/showth...rom-this-*POLL*
    you may have solved everyones problem
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by vectra ste View Post
    Thanx for the feed back ste , forgot to mention that i re attatched the small matal band when putting back together with a jublee clip
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    Quote Originally Posted by Richard.roberts View Post
    and i just realised i spelt right when it should on been write lol
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    I didnt even notice pmsl
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    can you e-mail me the pic's ill put them up for you
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by dan danz View Post
    Soz dan boy i didnt take any thought of it but i dont know how to upload n stuff, it is pretty simple, if you or anyone wanted to do it just remove the little filter piece out of the square piece on the side of the bcs, that way you dont even have to di-assemble the whole thing, if you know what i mean
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    ive got this problem since ive have the car. i think you need to be a premium member to upload pictures or host them from photobucket.
    Nov 2010
    East Midlands
    Trim : design
    Its very interesting but begs for some pictures - anyone know the part number for the bcs and how much - might be easier to replace it.
  1. Another Z19DTH flat spot/hesitation thread
    By Teapot in forum Engine & Drivetrain
    Last Post: 29th December 2012, 23:47
  2. Replies: 0
    Last Post: 8th August 2011, 16:39
  3. Flat Spot/Stutter or hesitation on 2006 1.8 VVTi SRI
    By Fireyfella in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 08:30
  4. 150 flat spot finally sorted !
    By Shrimpy in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 18:28
  5. flat spot/hesitation
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 16:53
flat spots in first and 2nd gear astra 2010
Z19dth hesitation
vec c estate problem with flat spot
vauxhall vectra estate flat spots
vauxhall vectra 2.0 turbo sri flat spot
520d flatspot
astra 1.9 flat spot sorted
flat spot fix insignia
flat spots in 2nd gear
vauxhall insignia flat spot 1st to second gear
