Thread: tapping from rear caliper/brakes
    Jun 2011
    manchester uk
    Default tapping from rear caliper/brakes
    Hi all
    I have got an anoying tapping coming from the rear caliper area.
    I have a 1.9cdti sri 2005 vectra
    This first appeared only on the nearside rear, it is like a tapping which gets louder when turning and went when i had been traveling for a few miles although not always, pads were low so i changed the pads both sides on removing the near side the caliper would not wind in i had to take it to my local garage to use thier equipment to wind it back in, this worked for a short while but it came back after a few days, i decided to change discs all round and again new pads all round that came with the disc set as well as a replacement caliper from my local scrap yard for the nearside which wound in with ease, i will point out out the offside caliper was fine and wound in no problem, i bled both sides before lowering the car.
    This time all was well for about two months before the tapping came back but this time on the offside only slight tapping which goes after a few miles but is more pronounced when cornering (left hand turn) sometimes i can hear a slight clank from the rear brakes like the pads making contact with the disc then applying? (the only word i can think to describe) when applying.
    Has anyone got any ideas, is there a specific way the handbrake is set up, is there somthing re the spring that goes on the caliper or a specific way to bleed the brakes?
    All help appreciated
    Simon
    Jan 2012
    Silverstone village
    Do the rear calipers have the anti rattle clips that is on the front?
    Jun 2011
    manchester uk
    Quote Originally Posted by mon View Post
    Yes they are on but can never fathom out how they actually do anything.
    Jan 2012
    Silverstone village
    Quote Originally Posted by bobsimes View Post
    They do work you will know when they aren't on.
    I would guess the disks may be warped but you mention they are only a couple of months old, Maybe try jacking the car up on the offending corner and manually spinning the wheel?
    Jun 2011
    wolverhampton
    Did u grease the metal contact points of the pad to caliper mount as it just sound lime pads rattling to me. Should be fixed with a bit of copper slip
  1. Rear caliper
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 23rd September 2012, 09:42
  2. Click from OS Rear caliper area when brakes applied
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2010, 13:40
  3. tinny tapping noise from rear of car
    By borolad2009 in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2010, 22:17
  4. Knocking rear N/S and tapping brakes - low speed...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2010, 21:40
  5. Tapping Noise from Rear N/S Wheel?
    Last Post: 14th January 2010, 20:04
