Thread: Deadlock not spring?
    Mar 2012
    Norway
    Default Deadlock not spring?
    Hi!
    I'm trying to deadlock my car with the method described int the owners manual, 2 clicks on locking within 15 seconds.
    However, I can't manage to deadlock it, the car simply won't react on the second click.
    Tried with the windows open to check the mechanical disconnection to the buttons inside and also to check the rain sensor/window autoclose feature.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    NOt all of them have deadlock.. mine dont.
    (plenty of wiring and changes to make that bit working.)
    Mar 2012
    Norway
    Oh, crappeti crap crap! Sometimes I just hate the spellcheck on the iPhone. Deadlock not spring?! WTF?!? Haha...
    Ok, I didn't know that. Too bad... Then the autoclose won't work either?
    Can it be something that interrupts the deadlock hopefully?
    Feb 2011
    Selby
    As Kenp said, some models (usually bottom of the range) didn't have deadlocks. And similarly some didn't have the window opening and closing from the remote and rain sensor function either.
    I don't have the specs for the Norwegian models unfortunately so can't check what your car should have.
    Engine : 2.2 Direct
    Autoclose via rainsensor Wont work either.
    But open close via keyfob should work.
    Bit there could be a fault in your system. But dont Think there is. A's diffent locks are needed to have deadlock
    Mar 2012
    Norway
    I think my car is somewhere in the upper section of the model range.
    I have:
    Open/close windows from remote
    open/close boot
    twin audio
    dual electronic climate
    rainsensor
    lightsensor (not active AFAIK)
    Parkingassistant front + rear
    AFL
    Easytronic
    Mar 2012
    Norway
    Is it some easy way to find if it's equipped with deadlocks or not?
    My previous Vectra B had it.
    Open/close via keyfob works, but it's a "nice to have"-feature with the rainsensor =)
    Feb 2011
    Selby
    That does sound like it should have deadlocks. I wonder if they've been disabled in software?
  1. how do you overcome a deadlock
    By vxr in forum Bodywork & Interior
    Last Post: 21st July 2009, 10:58
  2. Spring is in the air !
    By FIL 4822 in forum The 'Off Topic' room
    Last Post: 25th February 2009, 21:08
  3. how do i do the spring mod
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 13:20
  4. Double click/Deadlock
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2005, 13:24
