Results 1 to 10 of 11
Thread: Signum centre rear seat will not flip
    Jun 2012
    Nottingham
    Default Signum centre rear seat will not flip
    Please help,
    The centre rear seat of my car will not flip, it is stuck in the seat position and will not flip over to the centre storage / cup holder bit.
    We have had previous issues which I see documented on here, where the seat back will not go back up, however this element is working fine.
    Any help would be greatly appreciated.
    John
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Can you give us a little more info, is it firmly stuck, does the handle flap move?
    Jun 2012
    Nottingham
    Hi,
    The seat moves about an inch u[wards when you pull the handle at the front, but that is it, will not go any higher. It seems like something is catching or is stopping it from moving.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Sounds like something has fallen in there and jammed inside it. Are you able to see the inside, under the seat bit...? Have a look as you lift the flap and it raises as far as it can...
    Jun 2012
    Nottingham
    Will have another look when I get it back from Vx!
    Just had to put it in to try and sort out another issue of the engine cutting out when hot or wont start when hot.
    ****** typical when we are supposed to be going to Scotland at the weekend.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Just had this on mine , when the centre seat was removed it turned out to be a £1 coin
    Jun 2012
    Nottingham
    is it easy enough to remove the rear seat?
    would make sense for it to be something that is stuck, especially with the rubish the kids knock around with in the back of the car.
    Just got to get the engine issue sorted now.
    South east
    Quote Originally Posted by Bomber G View Post
    You need to remove the two main rear seats before you can remove the middle seat.
    Jun 2012
    Nottingham
    Can you do this using normal spanners or is it a case of having to use star drive tools?
    Jan 2012
    Milton keynes
    Mileage : 38100
    I think they are torx heads
  1. Signum centre rear seat won't fold down.
    By markthedoc in forum Bodywork & Interior
    Last Post: 12th March 2012, 22:15
  2. centre rear seat belt
    By georgialeapee in forum Introduce yourself.
    Last Post: 20th April 2010, 13:13
  3. Centre Rear "Seat" on a Signum
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 23:33
  4. Signum - Who can sit on the rear centre seat?
    By Trundlebus in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2007, 12:02
