Thread: help needed....
    Aug 2011
    sunderland
    Default help needed....
    i have noticed a creaking when turning the steering wheel and coming from the front wheels. any ideas what this can be?
    also sometimes the car can be a rocket and other times can be sluggish then suddenly shoot off.
    ideas on both please
    thanks in advance
    Aug 2011
    sunderland
    forgot to mention its a 1.9 cdti sri 55 reg
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    have you cleaned the egr out lately and the boost sensor this may be because its sluggish
    check the front springs are not broken
    Aug 2011
    sunderland
    no i aint, cheers for that mate!
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Creaking sounds like the top suspension mounts
    Aug 2011
    sunderland
    are the mounts an easy repair? i know nowt about cars really
    thanks.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    creaking does sound like top mount bearings
    have a look a this vid you could do the egr clean and boost yourself
    http://www.youtube.com/user/Absolute...?feature=watch
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    check the power steering fluid level as well
    Jan 2012
    Gloucestershire
    Inconsistent/sluggish power:-
    1) Clean/replace EGR
    2) Clean/replace boost sensor
    3) Check/replace vacuum and boost pipes.
    These really are simple to do if you can handle a spanner and set of allen keys. Read the How2s on the site, and give them a go, with a mate who has a set of tools if necessary. It can save you a few hundred quid.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    a bit of info for you about creaking
    http://www.vectra-c.com/forum/showth...iator%20mounts
    and Check vacuum and boost pipes for leaks as mentioned above
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
