Thread: Changing Plugs, Hot or cold engine?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Changing Plugs, Hot or cold engine?
    As hot things expand, and cold things contract - generally speaking, should you change your plugs when the engine is hot or cold, and does it even make a difference??
    Mar 2012
    Walsall
    if you try it hot.. wear gloves.. fire-proof ones at that..
    Oct 2007
    south wales
    To be honest, I have never given it much thought, so used to draining the oil, then changing the air filter and plugs while the oil is draining, they are usually warm...
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    I've changed it both ways, TBH, as long as you/they havent been over tightened them in the past then they should just pop out easily.
    South east
    Cold.
    Regular Member John Bishop's Avatar
    Oct 2010
    Depends whether they are seized or not. Also if they are sparks or glowplugs
    6 Post(s)
    Chances are, a garage will change them when the engine is hot at service time. Unless it's been left there overnight.
    Shouldn't really matter though as they'll be the same temperature as the engine.
    CHESHIRE
    may i jump in here and ask a quick question glow plug related , how do the leads come of the plugs someone said they just pull off , concerned if i pull ant harder going to damage something cdti 150 .
  1. Replies: 0
    Last Post: 24th January 2013, 18:50
  2. Changing spark plugs 2.8T
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 14th June 2012, 12:28
  3. Changing Spark Plugs
    By Chris SRi in forum Troubleshooting
    Last Post: 7th October 2011, 21:50
  4. changing plugs
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2008, 20:23
  5. Changing plugs on 1.8
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 23:59
