Thread: need advice on removing bumper.
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    Default need advice on removing bumper.
    right i removed the 2 screws under each wheel-arch the 4 plastic nail things and the 2 screws underneath and the 4 screws on the top ,unclipped it at the sides but cant get the blummin thing to budge in the middle am i missing something .?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    nope that should do it i think
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Like mrk said should come off mate,thats all i did
    Jul 2011
    UK
    Year : 06
    Lift it up from the top at the black bit and pull it out at same time
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Is it not budging at the top or bottom..IIrc the first time i took my bumper off there were extra screws on the underside of the bumper..I took these out and a sharp pull bumper off..hth
    Jan 2012
    wales
    Quote Originally Posted by dippy27 View Post
    yeah its the bottom bit that wont budge,will have a look for more screws. cheers
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by montyfert
    2 screws in the middle if I can remember
    11 Post(s)
    Quote Originally Posted by montyfert View Post
    Hopefully not by force?
    You should half undo the top bolt, then push it back in and then continue undoing it.
    This moves a slider mechanism that unlocks the bumper from the wing.
    Make sure the slider is in the correct place upon re-assembly.
    Sorry if you already knew.
    Jan 2012
    wales
    thanks didnt know that . will have a look tomoro
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Small torx bolt in front of the front wheels - I found this out on advice from a panel beater to reattach the bit i ripped off on a kerb!!
  1. Having trouble removing bumper!
    By willywoofter in forum Bodywork & Interior
    Last Post: 9th October 2010, 18:06
  2. removing sri bumper insert
    By cranny 27 in forum Styling
    Last Post: 20th November 2009, 20:55
  3. Removing top grill an 'V' from bumper
    By petersaxon in forum Bodywork & Interior
    Last Post: 10th June 2009, 20:23
  4. help removing rear bumper
    By simon7257 in forum Styling
    Last Post: 14th September 2007, 20:42
  5. Removing rear bumper
    Last Post: 10th February 2007, 17:42
