Thread: What is this and how do you undo it!?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default What is this and how do you undo it!?
    I'm trying to replace a coolant pipe as its heavily corroded and I dont want it to fail or just transport rust around the engine....
    So... how do I undo this clasp and then reuse it???
    Thanks!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You dont re-use it.
    Thats a hose clamp that you when you buy they are open - and then you 'clamp' together with pliers.
    You will need to carefully open it with a small flat screwdriver - or cut it off.
    Nov 2010
    East Midlands
    Trim : design
    And replace it with a jubilee clip
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by alcutler View Post
    Agree but be careful. The reason these 'hose clips' are used is that they are supposed to grip the pipe evenly around the pipe. Its quite easy with a jubilee to snag it in one place etc.
    Be OK - dont overtighten and you should be fine.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Thanks! I'm glad I didnt try now then!
  1. unable to undo any of my valve caps
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 22:18
  2. anyone want to undo the air box mod
    By ks246 in forum Parts for sale
    Last Post: 30th May 2009, 18:22
  3. Help - can't undo locking nuts/how do you remove spinning collar?
    By nigec in forum Suspension, Wheels & Brakes
    Last Post: 19th May 2009, 20:37
  4. How do you undo the aerial plug?
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 20:25
  5. Changing rear siggy springs, is this the bolt to undo
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2008, 04:44
