Results 1 to 10 of 15
Thread: Omega/vectra b 2.2 petrol help if possible
    Jun 2011
    Fife
    Default Omega/vectra b 2.2 petrol help if possible
    I know this isn't really the place but an off chance that somebody has had the same probs I'm having with a friends car. 2.2 w reg petrol. Car starts fine. Doesn't rev worth a toss. When it does rev if I hold it at 4 thou rpm after a couple secs the engine dies back down to tick over n almost stalls. When driving every time I lift the clutch wi the revs up it won't pull and kangaroo's all down the road. It tries to accelerate well under full throttle but only full throttle. Tried cam sensor. New plugs. New inlet pipe from maf to inlet manifold. Thinking maybe maf sensor/coil pack/egr valve.
    Any help appreciated.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    i was thinking coilpack
    i sure someone else will be along soon to help
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Coil pack ibwould say
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Is it an Omega or Vec B as the 2.2's in the Omegas are totally different to the Vec's.
    Jun 2011
    Fife
    It's an omega mate. I thought they were the same just mounted for rear wheel drive.
    Jun 2011
    Fife
    Ordered coil pack and maf. Need to start somewhere
    Jan 2006
    Norfolk
    The Omega has a timing belt opposed to a chain used in the 2.2 Vectra as far as I recall
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Unplug the MAF and see if it runs. Mine did this on gas and a new MAF cured it. If you unplug the sensor you'll know. And yes they're different engines - Vectra has the Z22SE whilst the Omega has the Z22XE.
    Jun 2011
    Fife
    Yeah your both right. Different engines and omega has timing belt. If I unplug it it makes no difference on tickover anyway. Not tried running it?
    11 Post(s)
    Quote Originally Posted by bowler View Post
    And the 2.2 Vectra engine (originally in the VX220) is an all alluminium engine.
    The Omega 2.2 is a cast iron block, and alloy head, IIRC.
  1. Omega Seats into Vectra
    By OpelVectraC in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 11:32
  2. Will Omega Alloys 225/55 16 Fit my Vectra?
    By darren71271 in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2011, 18:59
  3. Omega and Vectra-C meet N.Ireland 28/6/09
    By fenderguitar in forum 2009
    Last Post: 2nd July 2009, 00:08
  4. will omega alloys fit vectra?
    By scunner in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2008, 22:55
  5. Omega 2.5 V6 petrol
    By vecest in forum Engine & Drivetrain
    Last Post: 26th November 2007, 18:25
