Results 1 to 10 of 16
Thread: Da starter kits
    Full Member
    Nov 2009
    Warrington
    Default Da starter kits
    hi guys. ive been wanted to get myself a da polisher for a while now and more importantly lean how to use it correctly. the thing im most worried about is doing permanant damage to mine or anyone elses car. ive just applies polish with hand before and had good results on my car but when i came to do my sisters car which was swirled to death, the results were poor. ive seen a few lads using the megs da polisher. so after some advice please on thoughts for a beginer. cheers ears.
    Jul 2011
    UK
    Year : 06
    Check the thread below mate search on autobrite at da kits I got mine there
    Full Member
    Nov 2009
    Warrington
    [QUOTE=marc vectra sri;1833562]Check the thread below mate search on autobrite at da kits I got mine there[/QUOTE
    am i right to be worried aboiut causing damage with one of these, i need to do a lot more reading up on them and the pads etc
    Jul 2011
    UK
    Year : 06
    I haven't with my car I really give it some going with them I've used heavy cutting pads heavy cutting compounds and ud have to leave the da in on position for some time to do damage I use my car as a testing car and I've done no damage to mine atall no burning ect
    Full Member
    Nov 2009
    Warrington
    to look at my car (other than the massive keyed panel) you cant see swirls at all unless you look very close with a light but its other cars people have asked me to do so wouldnt want to damage them, also do you have to be careful of the laquer/clear coat when polishing
    Jul 2011
    UK
    Year : 06
    Yer u need be carefull when doing it and take ya time took me 5 hours just to polish mine keep spreading the polish and don't stay in one place for a long time uselly takes around 6 passes going from speed 3 up to speed 6 then back down to speed 2
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    You will be fine with a DA. TBH the golden rule is never stop the polisher from moving, that's when damage to the paint can occur as it overheats. Get yourself a Das 6, Meguiars Polish pad and a Cutting pad, Meguiars Mirror Glaze #82 & 83, thats all you will ever need.
    Woodbridge
    Quote Originally Posted by marc vectra sri View Post
    your right in what you are saying and TBH you would have to really mess up with a DA to burn through, all though it is possible. Marc have you had a PTG on your paint? I only ask as I also used my wifes car as a practice car but after about 1.5 years practice I have taken a lot of paint out of the car. We all think that a DA will be fine, but I have polished peoples cars with only 80 - 100 microns, which is not far from solid paint and if your not careful burn through can easily happen from what would be normal practice on any car with reasonable paint. Resprayed areas will also cause concern because you can't gauge how soft the paint is and sometimes you cant tell just by looking if an area has been resprayed. Dont be scared of using a DA just learn the facts about the paint your polishing first, if you have loads of it all over the car then go mental and practice till the cows come home.
    Full Member
    Nov 2009
    Warrington
    Quote Originally Posted by Ginge7289 View Post
    Thanks for all your replies guys, I just didn't know how far I'd have to go ie would I need a lpaint in and paint gauge etc
    And then it's a case of all the gear no idea haha.
    Jul 2011
    UK
    Year : 06
    I ain't got one of them mate but I no longer need to use the da on my car now as its corrected Infact that's a lie I ain't touched the roof yet lol al only use a finish pad on my car now buffing off wax for a equal spread safes time
  1. Non-starter
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 19th July 2012, 18:32
  2. vec c possible starter ??
    By neilb1 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2012, 16:50
  3. non starter
    By marky1 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 17:06
  4. Non Starter
    By andyguthrie in forum Engine & Drivetrain
    Last Post: 9th October 2010, 13:31
  5. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
