Results 1 to 2 of 2
Thread: Idle missfire on my signum
    chelmsford essex
    Default Idle missfire on my signum
    Hi can anyone help me..i have a missfire on idle with my signum o6 plate..so far its running ok when driving normally but on tickover its lumpy.
    so far i have replaced the coil pack and spark plugs,replaced the air flow metre,had the cylinders checked and the compessions are fine...the fuel pressure regulator has been tested and its ok..there is no EGR valve in this modle as it was removed in may 06 by vauxhall. so now im at a lose as to what to look for has anyone got any idea's please.
    Mileage : 000
    Is your motor petrol as it could be the air control valve sticking, a squirt of carb cleaner can do the trick.
  1. signum 2.2 missfire
    By jimr1 in forum Engine & Drivetrain
    Last Post: 19th September 2012, 15:09
  2. Signum cdti idle/temp problems
    By Kar54 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 12:47
  3. Signum 2.8V6T idle speed high
    By BYGino in forum Engine & Drivetrain
    Last Post: 30th June 2011, 20:59
  4. Replies: 4
    Last Post: 12th December 2008, 12:47
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
