Thread: oil pressure light vxr vectra
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default oil pressure light vxr vectra
    well had a little suprise today when adam was doing my smd converstion we found that the oil pressure light had been taped up so it coudnt be seen
    is anyone able to help me out on what i need to do or check to see what the problem could be
    i have had the veccy since Easter weekend and its running fine with no issues
    what kind of issues would you get when the oil pressure light is on
    my first thought is oil pressure switch? does anyone have a part number for it
    all info would be great
    on a side note great work carried out by adam
    spoons
    Guest
    Oil pressure light has been found to come on in very rare occasions and then go off again never to return.
    It happened to me once in 5 years of ownership on my Vectra VXR. No ryme or reason, just came on. Checked the oil level, everything was ok. Wasn't racing around, or high speed. Was sitting at traffic lights if I remember correct so pulled over and checked levels.
    Anyways, it seems this same thing happens to other Vectra VXR owners occasionally as well. We think its the pressure switch plays up now and then, but not for ongoing periods, just once in a blue moon.
    Jan 2008
    ipswich
    hi i got a vectra 1.9 cdti mine came on last sat coming home from the highlands of scotland came on at bury st edmunds that was
    the first time in 5 years too everything was fine tho
    Mar 2007
    swindon
    my guess is that the last owner has covered it to hide the fact it was on so will keep an eye on it if its on all the time over this week think im going to change the switch if it stays on will also do an oil change as read somewhere if crap oil has been used may not help
    what kind of things do i need to watch out for (just in case)
    Mar 2007
    swindon
    Quote Originally Posted by johnboyna54 View Post
    did it stay on all the time after ?
    Jan 2008
    ipswich
    turned the car off and it stayed off luckly but shes due for oil change
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    A guy on vxr online had this prob everytime he booted it. He replaced the pressure and all ok
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Oil pressure light delay
    By Gazze in forum Engine & Drivetrain
    Last Post: 29th January 2012, 14:48
  3. Oil pressure warning light
    By shadders in forum Troubleshooting
    Last Post: 5th January 2011, 17:18
  4. flickering oil pressure light
    By collee in forum Engine & Drivetrain
    Last Post: 15th June 2009, 17:20
  5. Low oil pressure warning light
    By volvo12345 in forum Engine & Drivetrain
    Last Post: 6th January 2008, 18:57
vectra vxr oil pressure light
vauxhall vectra oil pressure light
Where is oil pressure switch on vectra 19cdti
where is the oil pressure switch located vectra 54
