Thread: Vectra C 1.9 CDTI 120 Help Please
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Talking Vectra C 1.9 CDTI 120 Help Please
    Hi guys.... Ive recently bought a 1.9 Cdti 120.... SXi
    Just a couple of things really......
    My MPG isnt the best... what could it be?? Ive cleaned the boost control sensor thingy out.
    Im getting around 80miles to £20
    Any surgesstions would be grateful...
    2nd
    Ive bought a GSi vec c....
    And im taking everything of that, that makes it a GSi and putting it on my vectra.
    Few questions really...
    Xenon headlights... are they just plug & play??
    Its got climate control and trip computer bit, is that just plug and play??
    Auto dim rear view mirror... easy to fit??
    Rear electric windows??
    There are a few other bits and piece like interior im going to swap over, but they are pretty straight forward..
    I do have op com so if anything needs programming, can i use that? If not, i can get hold of Tech 2 as well...
    Thanks everyone in advance, when i get a min, ill grab some pictures of the car.
    Thanks!
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Also i want to get a DTUK box, does anyone have one here that will work with mine? Thanks
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Someone must be able to helP???
    scottish region
    All parts should be interchangable yeah and check eBay for a dtuk box I had one from a 150 on my vectra 120 with no probs
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Xenon Headlamps as Far as I'm aware are not just plug and play and the headlamp looms will have to be modified accordingly. They will also need to be activiated via a Tech2 session. Then you'll have to fit the headlamp washers and auto level sensor... Just get yourself some HIDs.... much easier. http://www.vectra-c.com/forum/showth...System-Install
    Dimming mirror is very easy... just pull down the headlining first and see if you've got the plug there already, if not you could just rip the one out of the car that has the loom already fitted. http://www.vectra-c.com/forum/showth...28With-Loom%29
    Rear electric windows... http://www.vectra-c.com/forum/showth...ectric-Windows
    Climate control I'd say you'd be better off staying with the AC as I'd reckon thats far from an easy job.... plus a Tech2 session to have it activated etc.
    MPG problems... no idea... maybe just a decent service?
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by Vectra Adz
    2nd
    Thanks!
    Headlight plug and play
    Auto dim mirror can be plug and play if loom there if not just wire it into a ignition live and a earth
    Rear windows and be put in if loom is there if not bit more than that but there is a how 2
    Fuel clean ya egr out change filters
    Jan 2012
    Milton keynes
    Mileage : 38100
    As I said Xenons are not plug and play as they have different connectors and therefore the looms will have to be transfered... see these threads....
    http://www.vectra-c.com/forum/showth...ht=retro+xenon
    scottish region
    Yeah but he has everything there so can be done easy enough
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Hi guys, thanks for the reply... I will have a look into the wiring etc regarding the xenons/hids
    With regards to giving it a service... I give it a full service inc belt when i got the car couple months ago. All genuine stuff. Only thing i didnt change was the pollen filter.
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Vectra 1.9 CDTI Sri Versus 3.0 CDTI V6 Sri
    By collateral in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 20:18
  3. 0 to 60 in a vectra cdti 150
    By chrisgettings in forum Diesel Engine related
    Last Post: 25th October 2007, 20:39
