Results 1 to 10 of 15
Thread: 2.0 dti turbo question
    Lincoln
    Default 2.0 dti turbo question
    ok just a quick question car runs fine etc just white smoke on start up took it to Garage said might be turbo defo not headgasket as does not over heat or mayo and very rare be valve stem seals was going to buy a turbo is it just a case of taking my one off and adding the new one??
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    is it losing any oil or water ?
    Lincoln
    Quote Originally Posted by DTi Elite View Post
    havent seen any mate,
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Whitey/grey smoke on start up is just unburnt diesel. Don't worry about it if it clears after a couple of seconds.
    Lincoln
    Quote Originally Posted by cont1204 View Post
    doesn't clear after few secs takes about 10 mins once the car is fully warm no smoke at all but say if i go to asda do shopping come back to it smokes again
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    100% sure it's not just condensation in the exhaust? My car will sit there steaming away for a while if it's been cold out. Turbo isn't water cooled so I'd expect blue smoke if anything from burning oil there.
    Lincoln
    defo not condensation i uploaded a you tube video but no reply http://www.youtube.com/watch?v=Zz0J_cqBg6U&feature=plcp that was on a good day normally 10 times worse then that
    Regular Member krazylegz's Avatar
    South Shields
    That does look quite bad tbh, not sure what it could be, if it were the turbo I'd have thought it would be blueish with too much oil getting through the seals, white does usually indicate steam as in water getting burnt but if you say it's not losing any, god knows?
    Lincoln
    Quote Originally Posted by krazylegz View Post
    same here mate no idea,i havent had to top up the water or oil thought id be doing every other week if it was
    Regular Member nwmlarge's Avatar
    May 2012
    United Kingdom
    might be a leaking injector ?
  1. turbo question
    By jock in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 19:14
  2. Turbo question
    By Shortland78 in forum Engine & Drivetrain
    Last Post: 11th April 2011, 19:17
  3. turbo question help
    By markgcdti in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2011, 06:10
  4. Question about the 3.0's turbo
    By Celes in forum Suspension, Wheels & Brakes
    Last Post: 26th August 2009, 22:01
  5. 2.ltr t turbo lag question
    By STAV in forum Engine & Drivetrain
    Last Post: 11th October 2007, 15:02
