Thread: Towbar wiring - gm dedicated harness
    Feb 2011
    IN A HOUSE
    Default Towbar wiring - gm dedicated harness
    Guys, Can anyone advise or confirm that i have to get Tech2 on the dedicated Harness when fitting a gm towbar and Harness, its all plugged in as it should be but the rear fuse board on the Estate where the main harness plugs seems to have no live feed - im pretty sure it need tech2 to say its there but not 100% - anyone help / advise ??
    Thanx
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    yeah the towbar module needs to be activated in the rec via tech2
    Feb 2011
    IN A HOUSE
    Thanks for confirming that mate, much appreciated.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Mine didn't - just plugged it in and it all worked straight away.
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by Richie_rich View Post
    no probs anytime
    check the fuses etc as thats what it just may need but if youve got no power and everything is fitted and its not working then
    the towbar module will need programming.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What do you mean when you say live feed? Have you have you just fitted a 12n socket or bot 12s and 12n?
    Have you tried it with something plugged in as it will only work when there is a plug physically plugged in (12n)
    Failing that try the "hard reset" described in the how2 section.
    Feb 2011
    IN A HOUSE
    Yeah i have fitted both sockets and plugged in all the wires as per diagram - tbh i didn't plug anything in the sockets other than a circuit tester to see if anything flashed or lit up when you put indicators on or lights etc etc and nothing lit up, so i assumed that there was no feed - i checked the main plug live output (red wire) and again nothing lit up so again i assumed no feed that's why i put the post up on here - now its in the garage at the min and i have had to get the code to access ecu but its saying that there's nothing needs activating.
    It seems i may just need to plug summat in it then - lol - what a dumb ass i am if that works, will get them to try that tomorrow and come back and advise.......
  1. Do I need a Wiring Harness?
    By weidass in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 22:17
  2. Towbar wiring - dedicated or just splice in?
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2012, 12:40
  3. Dedicated towbar wiring
    By cus2000 in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 12:48
  4. How do i know which wiring harness i need?
    By caigey in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2009, 21:49
vectra c towbar wiring plug
vectra towbar wiring diagram
towbar wiring diagram vauxhall vectra
wiring diagram towing for 2007 vectra
