Thread: rear door opening - - - - strange one
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default rear door opening - - - - strange one
    Right, a slightly strange issue.
    My rear drivers side door won't open from the outside handle, but will open from the inside handle (when unlocked of course !)
    Any ideas? and will it be covered in 3rd year warranty?? (04 1.8 LS)
    TIA
    Can't remember how all the mechanics are laid out for the door handle release, so can't give an answer.
    As for warranty, can't see any reason why it wouldn't be covered if it's a mechanical issue.
    SOMERSET
    If you are not covered under warranty you could try and swap the rear door handles over buy taking out the rubber bung(door open), using a torx and seeing if there is a issue with the handle itself. If not it may need the door card coming off.
    Best of luck
    Regular Member simac's Avatar
    Wirral
    Sorry m8 but I think one of the only things not covered by the Warranty is the door handles, but whether that means them being operative or actually breaking physically i'm not sure.
    Some of the bodywork and fittings only have a 1 year warranty which is pants.
    Good luck !
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Currently it would fail an MOT (as the door cannot be opened from the outside), does that count for anything? As it is in 'unroadworthy condition' due to mechanical failure.
    I'm going to ring my local dealer and ask what they reckon. If it's not covered, I'll do it myself. Not paying VX to do the work when I'm perfectly capable of doing it myself.
    Jul 2006
    That's the spirit!
    Quote Originally Posted by simac View Post
    The one year warranty is only trims and paintwork. If the problem with the handle is a mechanical one then it is under the 3 year warranty.
    Nov 2005
    scotland
    this might sound stupid but is the child lock on- there is a small catch on the door lock that you turn with a key. it explains in your handbook.
    Regular Member SIIM's Avatar
    Burnley
    the child lock should stop you from opening the door from the inside not the outside.
    Nov 2005
    scotland
    my mistake read it wrong
  1. Taking door card off without opening the window
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2013, 20:30
  2. Door not opening
    By sproket in forum Bodywork & Interior
    Last Post: 29th June 2012, 08:36
  3. width of estate rear door opening
    By vansboy in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2010, 19:36
  4. Chime when opening door.
    By TrevF in forum Bodywork & Interior
    Last Post: 30th October 2008, 10:19
  5. Clicking sounds when opening door
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2006, 05:25
