Thread: Oil catch tank benefits......
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Default Oil catch tank benefits......
    I know the main reason for doing this is to stop the oil going back through inlet and so on but when fitting one you also stop the hot vapours being sucked in aswel does this actually benefit pick up on acceleration as you are only sucking in cold air?
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Bump
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    To be fair, I doubt it. The temp sensor is usually before any return feed of the can so the temperature change won't be noticed by the ECU, so no changes... IMO.
    Still in process of fitting one to mine however
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    on my subaru i just went vent to atmosphere with a arch in the hose to hold the oil mist in suspention and not drip oil onto driveway
    oil catch tank does the same thing with a bit of bling but you see what oil has accumulated and drain iy
    inlets where breathers went into were blanked off
    made my whole inlet / turbo internals / intercooler internals/ manifold internals where the fuel injectors are / valve stems etc spotless over a short period of timewith no gumming up which also reduces the oil the engine burns which isnt good for lambda and cat if fitted
    thats the idea to do away with the pcv setup on modern cars which just gunk up over time
    no performance gains or ill effects
    Devon
    I fitted one to my GSi just over 2 years ago. There's absolutely no benefits on performance etc, but my TB and inlet manifold are now spotless, and all I have to do in return is empty the catch tank every 4 weeks or so!
  1. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  2. oil catch tank
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 00:25
  3. oil catch tank
    By spidermonkey in forum Engine & Drivetrain
    Last Post: 16th August 2011, 14:40
  4. oil catch tank
    By 22ultra in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2009, 13:10
  5. Oil Catch Tank
    By JSYSH466Y in forum Petrol Engine related
    Last Post: 28th February 2009, 12:11
