Thread: 4 wheel alignment again.!!!!!!!
    Aug 2010
    Leeds
    Default 4 wheel alignment again.!!!!!!!
    Done just 15k and the car needs 4 wheel alignment again on rear wheels scrubbing on outside edges.
    This was done at 8k now on 23k i know pot holes can knock it out but does vectra seem to suffer more?
    Sep 2010
    Well I've owned 3 Vectra Cs now and never had this issue on any. Only had 4 wheel alignment done on the last two. I do lots of miles too and all my tyres wear evenly.
    Aug 2010
    Leeds
    Had it done today the tyre thats the most uneaven according to them was the one thats ok the other side needed adjusting and set up the front end which was a bit out.
    £45.00 all in ready for the new tyres which are ordered today.
    Regular Member amand's Avatar
    Feb 2011
    west London
    tell me about it. i went to get it done and they ended up snapping the toe bolt. ad the front left camber wont go any further. Don't know why
    Something clearly wrong if the alignment needs adjusting again at the next tyre change
    Was it rechecked after the initial alignment?
    It is normal practice to check and adjust, and if adjustment was required to recommend a further check at between 500 and 1000 miles
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by Bigtee View Post
    You should have it done when new tyres are fitted really, not before.
    Jun 2011
    wolverhampton
    Please don't fit budget Tyres either as these can wear very odd ways at times. Defo only have it checked with new Tyres on not the old though
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I assume that the rear suspension arm has been checked for wear. Biggest cause of worn rear tyres on the Vectra
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
