Thread: help... again lol
    Regular Member farmboy91's Avatar
    Aug 2011
    ipswich
    Default help... again lol
    Had the car diagnosed yesterday and it came back that the abs sensor was causing the speedo n traction control n abs lights to come on the bloke then said to change the sensor the whole wheel bearing needs to be changed, this sound about right to every1? or are they muggin me off lol
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    I know the speedo takes it reading from the front nearside hub and if that fails you need to change the whole hub, not 100% sure if the abs sensor is replaceable though.
    Aug 2011
    ipswich
    yeh thats along the lines of what he was saying jus wanted to make sure lol thanks
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Had a look on Vauxhall World Parts and and all that appears available is front hub, bearing and ABS sensor.
    http://www.vauxhallworldparts.com/va...387&partid=133
    TIS showing front hub and sensor as one part too.
    http://www.opeloem.com/vauxhall/vect...front_hub.html
    Aug 2011
    ipswich
    result cheers for finding that bit cheaper than the 1 they quoted me for
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    A few cheaper on ebay too. Not sure if they are handed, so id contact any seller first.
    http://www.ebay.co.uk/sch/i.html?_nk...nsor&_osacat=0
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    try cleaning the connectors the the sensor firs with a little contact cleaner this happend to mine i cleaned the connections and it was fine after that
