Results 1 to 3 of 3
Thread: windscreen noise
    northampton
    Default windscreen noise
    Hi, I have a small noise comming from the bottom left of my windscreen. It has been replaced lately. It sounds like a single big drop of rain hitting the screen every now and then, but not just when i go over bumpy roads..
    Many thanks..
    Like a cracking noise? If it is, it may just be the screen settling in. If so, give it a little bit of time but if it keeps doing it, take it back.
    If it's somewhere like AutoGlass they give a 12 month guarantee on the work. I had a screen fitted and it seemed to be noisy (wind noise) to the point I could eventually start to fell a slight draft coming in the passenger corner. Took it back and they replaced it no hassle. When they installed it the bead of adhesive had been moved a bit as they put the screen in, so didn't make a perfect seal.
    northampton
    sounds good thanks for the advice..
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. New Windscreen
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2008, 19:48
  4. Windscreen
    By gipps in forum Styling
    Last Post: 20th November 2006, 00:31
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
