Thread: Water in passanger footwell and it not the suttle tray.???
    New Member dannydoncaster's Avatar
    Jul 2011
    doncaster
    confused Water in passanger footwell and it not the suttle tray.???
    Please can someone help me. i have a Signum 53 plate and have alot of water in the passanger footwell and a little in drivers. When it rains, its as if somthing in the dashboard is filling up with water, because as you go around corners you can hear the water slushing side to side somwhere in the dashboard, then it starts falling out from behind glove box. Got the glove box out at the moment and all the left hand side of the passange footwell where the electrics are is soaked and carpet underneath is swimming. . I hve cleaned the scuttle try and even removed the rubber drain bungs just to stop it blocking so i know its not that.
    Hope someone can help me begining to lose the plot with the car.
    thanks............
    West
    you might need to remove the actual plastic scuttle clean all the area around the bottom of the windscreen & re seal it
    Full Member spennny's Avatar
    Blantyre
    As dh.dht said mate remove the scuttle and clear out the drain plug , it's prob full of leaves etc bunging it up
    Are your blowers working or has it popped the resistor ?
    Sent from my iPhone 4s using Forum Runner
    Jul 2011
    doncaster
    Thanks will try today, when removing wipers the bolts seem very tight did not want to force them is this normal??
    Jul 2011
    doncaster
    Quote Originally Posted by spennny View Post
    Blowes work on 2 3 4 never worked on 1 since i got the car 4 years ago, water problem only started this year.?
    West
    Quote Originally Posted by dannydoncaster View Post
    they have probably never been undone before, the panel is not comming out without removing the wiper arms so just put gentle force or an extension bar over the spanner/socket
    Jul 2011
    doncaster
    Thank you going to give it a try today as it rained most of yesterday. :-(
  1. Water in passanger footwell and not the scuttle drain???????
    By dannydoncaster in forum Engine & Drivetrain
    Last Post: 17th June 2012, 12:49
  2. water in footwell
    By jsnlvxr in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2012, 12:54
  3. Water in osr footwell
    By T555DAN in forum Bodywork & Interior
    Last Post: 20th September 2009, 21:17
  4. Water in my footwell !!!
    By Rocky Balboa in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 12:20
  5. water in footwell
    By silky in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2007, 13:55
