Thread: ecu reset
    northampton
    Default ecu reset
    is there anyway of resetting the ecu. I wish to reset the fueling...
    Many thanks in advance..
    just disconnect the battery for about 20 mins..that will revert it back to factory settings..
    Disconnect battery for 30 minutes, that'll definitely reset it. It may even do it with a shorter time disconnected, but 30 minutes will definitely be sufficient. Just nip back in and have a cup of coffee!!
    Edit: Doh!, you beat me by nanoseconds Mark!
    northampton
    many thanks..
    Regular Member Xorro's Avatar
    Northants
    What benefits can be got from resetting the ECU - I understand that it is supposed to learn your driving style, but is there any possibility that you may get an improved MPG?
    morton
    i'm hanging on this thread ! as i fitted my filter a week ago but did not reset the ecu ! so if an extra improvement can be made ? i'm going to do the same !!
  1. ECU reset
    By wilson002 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 19:15
  2. Sat nav reset.
    By welshboy in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 03:12
  3. EML reset
    By paul_sri150 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 14:15
  4. ECC Reset??
    By colalowe in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2008, 20:42
