Thread: Catch Can Placement and Pipework
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Catch Can Placement and Pipework
    Well my budget catch can arrived
    Going to use this mini compressor filter, with the filter slightly modified.
    I'm worried about the pipe work though and having kinks in it, but not worried enough to start spending loads on various elbows to fit properly lol
    Can anyone see any issues with the path below? I'm going to attach it to the engine cover bracket (yellow) once I've knocked up a metal bracket.
    It has a release valve at the bottom when the pressure drops, i may block this or add a small 4mm pipe and just vent under the car...
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    That looks like the oil most would come out ok. Will your compressor filter allow enough air through? It needs to be free flowing to avoid any pressurisation.
    Sodding Typical on Sea
    I mounted mine on the bulkhead between the expansion tank and strut top routed the pipes along the back of the engine and must admit am very happy with the result. Now I intend to monitor the lines for return oil into the intake stream.
    23 Post(s)
    Mileage : 110k
    Yeah mally, I've modified the filter so it sucks up under rather then through the thick filter...
    Just messed with some old hose this morning and it'll bend without compressing shape by the looks... I'm also going to monitor the gas temp of the gas before the catch can, just waiting for my gauges to turn up
  1. drl placement ?
    By montyfert in forum Styling
    Last Post: 28th May 2012, 21:25
  2. TV aerial placement
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2010, 05:39
  3. Catch tank pipework question
    By Vid in forum Petrol Engine related
    Last Post: 3rd June 2008, 21:53
  4. Amp placement
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2006, 11:22
catch can on vectra c z19dth
