Thread: Rear suspension knock
    Regular Member RollingStone's Avatar
    Jun 2012
    Luton, Bedfordshire
    Engine : 1.9cdti DTUK CRD2
    Default Rear suspension knock
    Hi guys
    I suspect I need new rear anti roll bar bushes but wonder if you guys have any insight into my problem.
    I've had the car about a week now and the knocking has happened since day one, it appears to be coming from the rear off side however it knocks if you bump either near or off side wheels which would suggest to me its something that links both sides hence my ARB suspisions. The ride hight on the back looks a tad lower than the front and the camber of the wheels is more than i would expect but this might be unrelated.
    Anything you can contribute will be welcomed.
    Also are these polyflex bushes any good?
    Ta
    Regular Member Jekyll & Hyde's Avatar
    Walderslade Woods,Kent.
    If you have a trolley, and stands and the weather is permitting, get the rear wheels off and have a look for broken/cracked springs, broken damper mounts, splt, or perished rubber bushs, plus look for gaps between the bush and the rodding going through it.
    Theres a lot to look for as there are quite a few components, if your not sure what to do/look for, take it to a formula one, or kwik fit they will normal are a good look round for free.
    Or have alook through the How 2 section on this web site as there are loads of helpful stuff, and a lot of pictures showing what to look for.
    Hope thats some help.
    Quote Originally Posted by RollingStone View Post
    Possible the rear shocks have reached the end of their life, hence the sagging at the rear
    Equally, the rear springs tend to snap right at the base, and almost impossible to spot without very close inspection
    Alternatively the front shocks / springs have been replaced, everyone seems to report this once the originals have been replaced
    Regular Member BBMadness's Avatar
    Apr 2012
    Merthyr Tydfil
    I have the same issues and was just going to look at getting coilies
    New Member dannydoncaster's Avatar
    Jul 2011
    doncaster
    Had knocking noise from rear of both of my signums and both times it was the upper contol arms......
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    iv got a kind of knocking too and discocered it was the top two coils of my springs touching (new apex springs).
    they were bought specifically for my car so don't know what my next step is other than to replace them
    Jun 2012
    Luton, Bedfordshire
    Thanks for all the advice guys. I jacked the back wheel up and prodded and poked the bushes and drop links but they seem ok. Will get both the wheels off the ground and give the arb and springs a good look but if all else fails I think a visit to formula 1 in Stevenage a go.
    Jun 2012
    Luton, Bedfordshire
    Well it took me long enough but after changing the rear shocks the noise has subsided. I still hear it now and again but no where near as often as I used to, when I get some cash together will take it to a garage and let them have a proper look but I suspect the upper control arms have probably gona since the ARB bushes look brand spanking new.
  1. Diagnosing suspension knock
    By djlee in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2012, 11:41
  2. front suspension knock
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2011, 13:31
  3. Self repairing suspension knock??
    By RLFH470 in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2010, 13:43
  4. Sorry to ask about suspension knock again but...
    By Villers in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2010, 23:53
  5. Front suspension rattle/knock
    By damian s in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 16:47
