Thread: EGR valve question - 2.2 Direct
    Regular Member Boy Lard's Avatar
    Derby
    Default EGR valve question - 2.2 Direct
    Evening folks
    I've got the P0403 EGR circuit malfunction code showing. I guess it's probably the solenoid.
    If I blank the EGR and Tech 2 it 'out', should this solve any EGR related issues?
    Also, does blanking the EGR affect your emissions?
    Ta
    Boy Lard
    Jan 2012
    Gloucestershire
    Ask "rushy" as he usually knows these things, but I would guess that you either need to get the EGR functioning as normal by cleaning it and freeing up the soleniod or blanking AND Tech 2 deletion.
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    if its anything like the non direct it doesn't need tech 2 delete... but it does need to function.
    When i blanked mine i knocked it and the valve jammed so it threw up the dash symbol, one i gave it a clean and a tap and re fitted all was well...
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Or me yes it needs deletion mate blank it off job done
    Jan 2012
    Gloucestershire
    I think we're all agreeing...it either needs:-
    1) to function properly, so cleaned and solenoid working OR...
    2) blanking and Tech 2 deletion.
    On the 1.9cdti, (1) is simple but repeatedly required as a regular service dependent on driving style and journey type, but (2) is permanent! (2) also improves performance and MPG.
    Derby
    I think I'm leaning towards (2)!
    Thanks for your assistance guys.
  1. 2.2 direct.how do i remove and clean egr valve?
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 21:58
  2. Egr valve.can i clean & refit on a 2.2. Direct.
    Last Post: 16th September 2012, 23:28
  3. Egr valve on 2.2 direct.anybody advise on replacing one?
    Last Post: 13th September 2012, 20:45
  4. Help me find egr valve on 2.2 direct.
    Last Post: 13th September 2012, 17:20
  5. 2.2 Direct EGR valve question
    By andrewleighton in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:31
vectra c 2.2 direct egr valve clean
does the 2.2 direct have an egr valve
