Thread: Permanent live near front accessory socket ?
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    125 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Default Permanent live near front accessory socket ?
    As per the title does anyone know of a permanent live near the front accessory socket?
    I'm retrofitting a roof mount DVD from a zafira and have routed the wires through to there as can pick up an earth and a switchable live from there
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You could try the back of the HU, but id still go to the fuse box like the how 2 TBH mate. I've taken my wires down the rear and into the REC where there are both perm and ignition next to each other.
    THESE are worth the weight in gold.
    Swanley , Kent
    125 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    I did not want go near the rec as last time I did the rec threw a hissy fit and would not let plasmas tech 2 talk 2 it
    Vehicle : SRi
    Mileage : 137000
    Fair enough, running a wire from the front passenger fuse box up to the roof is easy and again you can take both constant and ignition from there.
    Swanley , Kent
    125 Post(s)
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    i did not think of that , i run the wires down the A pillar and through the fusebox to the centre console, it did not even cross my mind to stop at the fuse box
  1. Permanent live cigarette lighter socket for solar panel
    By craig20102010 in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2012, 13:25
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Making front aux socket permanently live
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2010, 11:32
  4. Can i make rear acc. socket permanent live ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 22:36
vectra c permanent live passenger fuse
