Thread: Injector diviation on 1.9 150
    Regular Member Mopar Man's Avatar
    herts
    Default Injector diviation on 1.9 150
    Had troubles since doing the broken cambelt and rockers.
    It starts and runs smooth and idles perfect, but is down on power and black smokes when driving.
    It has no fault codes and cleaned and checked all the usual,egr,boost and pipes etc. The only thing i found was the reading for the injectors as shown, is this normal?
    The car was fine before the belt broke and i made sure the cam and crank was marked and correct with the lines on the belt.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Needs 4 injectors by the looks of it, my 4 are all under 1.00
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you checked the seatings of the injectors since refitting? Start the car and spray some soapy water around the bores of the injectors. If there is any bubbling or worse (water spray) then the injectors may need to be taken out and re-seated.
    Fit new copper washers and clean the bores impeccably before re-fitting....make sure you use a decent torque wrench to tighten them up too
    Failing that try a bottle of Forte injector cleaner through it before spending big money getting re-furbed injectors
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    127 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    a freind of mine had similar readings to yourself along with some smoke, we removed the injectors and left them to soak in white spirit for 24 hours we refitted them and no more smoke and if my memory serves me right i believe the readings after were about 0.50 ish
    its worth a try because as you may well know that the injectors are not cheap
    herts
    Quote Originally Posted by jon1.8sri View Post
    Thanks guys.Did your friends loose power under 25000 revs as well?
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. My 3rd injector went
    By Kramel in forum Engine & Drivetrain
    Last Post: 20th August 2012, 06:55
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Injector 3
    By fadge in forum Engine & Drivetrain
    Last Post: 19th January 2009, 20:47
cleaning injector bores vectra
