Thread: Rounded off bleed screw - rear caliper
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Default Rounded off bleed screw - rear caliper
    As above, had to refit the old pads on both sides as couldn't get the screw off. What are my options? Google returned sod all for a new bleed screw, does that mean a new caliper? If so who are the best stockists?
    Thanks in advance
    Stuart
    scotland
    mole grips and some heat on the caliper body !
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Bleed nipple size is 10mm with a 1mm pitch iirc. As above mole grips and try pouring the contents of a boiled kettle over it to help shift it.
    Jul 2009
    Perth, Scotland
    Ok I have multi-grips which i tried but will give the heat a go. It was a 10mm spanner i used. Peachy on left one, sh*** on the right one!
    Thanks guys, Friday's job for me I think!
    Stuart
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Try a tapping a smaller single hex socket on as well, maybe an imperial size.
    Regular Member Ann's Avatar
    Jul 2011
    Northamptonshire & Derbyshire
    I'm sure this is for the bleed nipple, mike usually puts a molegrip on the nut and gives it a tap with hammer to loosen it.
    Jul 2009
    Perth, Scotland
    Did give the other socket a go, but wouldnt go over the ******ed bit! will try and get hold of a set of mole grips, if not, giving the multis a go
    Jul 2009
    Perth, Scotland
    Panic over nothing - G clamp on the piston and multigrips to wind it back and it was a dream!
  1. Rounded Clutch Bleed Screw
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 19:06
  2. coolant bleed screw
    By Allan-DTI in forum Engine & Drivetrain
    Last Post: 13th December 2012, 19:28
  3. cooling bleed screw
    By Alerxt in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2012, 15:34
  4. Rear brake caliper bleed nipple
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 18:45
  5. Rear break caliper + bleeding screw
    By wakala in forum Suspension, Wheels & Brakes
    Last Post: 20th October 2009, 12:32
