Results 1 to 10 of 11
Thread: Abs resetting
    crook
    Default Abs resetting
    I have a 2003 signum 3.0cdti
    problem is I have the dreaded abs light on, I have only had car 1 week,so fault could be anything
    does anyone locally have gadget for reading what the fault is
    Does anyone one have 1 signum 17" alloy for sale ?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Might be worth sticking up a wanted thread with a picture of the alloy your looking for bud.
    As for the code reading, I will be staying down at Barnard Castle for a week later in the month and can read the codes if you haven't found someone by then
    Is it just the ABS light, or has the Traction Control come on as well?
    crook
    sorry folks.......not abs.....airbag light
    had map sensor fault code,waiting for new sensor from dealers
    Nottinghamshire
    A common cause - and easy to check - for causing the airbag lights is the wiring connector on the floor under each of the front seats, especially if the seats are moved about a lot. Push the seats right forward and check the halves of the connectors are properly fitted together.
    If that doesn't sort it, it might be worth getting the code read as it could be related to wiring, an airbag, a sensor, or the ECU (and probably some other stuff too)...
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    if you get stuck give me a shout , I am in Bishop Auckland
    crook
    Do I have to take air bag connectors off then reconnect them or just check see if connection is secure ?
    crook
    Thank s DTI elite
    where do you get your bits from,
    Nottinghamshire
    Your choice really but if I was fishing under there myself, I'd disconnect and re-connect to be sure. They are connectors for airbags so take care. Make sure the ignition is off. For some airbag work you have to take the battery off and wait 10 minutes for the capacitors to discharge, but I don't recall anyone doing that for these particular connectors.
    Barrow In Furness, Cumbria
    Did you buy the car privately or through a garage? If its a garage then it would be better to take it back to them and get it sorted in case you damage anything trying to fix it yourself.
  1. what does resetting the ecu do
    By justin32 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 23:12
  2. key fob resetting
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 20:48
  3. Resetting the ECU
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 12:49
  4. Resetting the ECU
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 00:59
  5. resetting the ecu
    By lee_eardley in forum General Chat
    Last Post: 6th September 2007, 11:55
