Results 1 to 10 of 18
Thread: Advice on Adjusting a Signum's Boot Latch...?
    South east
    Default Advice on Adjusting a Signum's Boot Latch...?
    I've got an annoying rattle coming from the rear of the car that might be from the tailgate moving as the car flexes during cornering. Does anyone have any advice on how to adjust the latch/striker plate? Does the plastic/stainless steel trim strip that goes across the front edge of the boot opening need to be removed first? And do you just loosen the two torx bolts, move the striker plate and then tighten the bolts, or does the plate move up or down as you turn the bolts in either direction? Thanks.
    Barrow In Furness, Cumbria
    From experience with other cars, you loosen the bolts slightly and move the catch where you want it and tighten again. I'd leave them slightly tight and tap the catch slightly so its where you want it, just so it doesn't move too much too quickly.
    If its the tailgate making the rattle I'll bet that all you need to adjust will be the rubber bumpers on each side of the tailgate
    South east
    Quote Originally Posted by marktaylor View Post
    Tried that, no change
    Engine : 1.9 CDTi
    Are you sure its the boot as I thought the same and it turned out to be my centre seat backrest rattling.
    South east
    It might not be the boot, but I've searched high and low for anything else that it could be, nothing else is moving or making a noise; I even removed the stainless steel exhaust tips in case they were banging against the under-bumper skirt, but the noise was still there.
    Engine : 1.9 CDTi
    Wedge a bit of rag between the centre seat back rest and one of the seats (Between where the 2 leather parts would touch) to see if its the seat.
    South east
    Tightened the boot catch, no difference. Took the spare wheel and tools/jack out, no difference, but with the boot empty and boot floor lifted up, I took the opportunity of standing in the boot and jumping up and down, and I can hear a loud squeak coming from the N/S rear wheel area, so looks like it's wheel-off time.
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    check and see if the centre rear seatbelt in the roof behind the slider cover if its not on the magnet as i had a rattle just like yours
    and my centre seatbelt in the roof wasnt on the magnet to hold it.
    just a thought there for you
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by Rebellion View Post
    I had exactly the same issue........
    Your INNER bush on an upper control arm is worn.
    See http://www.vectra-c.com/forum/showth...IN!&highlight=
  1. signum rear wiper/boot latch
    By bigbazk in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2012, 15:19
  2. boot latch problem
    By wallace78 in forum Insignia car chat
    Last Post: 10th August 2011, 10:56
  3. Estate boot latch
    By a18nmk in forum Bodywork & Interior
    Last Post: 30th March 2011, 15:43
  4. boot latch
    Last Post: 11th November 2009, 22:55
