Thread: Estate Rear brake light fault?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default Estate Rear brake light fault?
    Hi Guys
    Just a quick request, any of you fine fellows ever had a fault as below on a 2007 Est Vec or similar.
    Got a warning on the dash of a brake light bulb, noticed the the rear outer, off side bulb wasnt working also the near side inner brake bulb, spent a little while replacing the off side bulb and then noticed the other came back to life. I naturally thought, result!. however since then i have replaced both bulbs, twice now and cant seem to clear the fault. the wiring hasnt been played with, only other than to change the bulbs, and they still dont work!
    Any ideas guys?
    thanks
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Mine did exactly the same, chased my tail with it for ages until I realised it was the bulb holders were corroded just where the bulbs touched them. Cleaning it up didn't work, I ended up jamming a piece of metal slightly wider than the corrosion in between the bulb and the holder so it connects with non-corroded metal and the problem went away.
    You can buy the bulb holder sections seperately I believe, I've just not got round to replacing mine as the error's gone since I did the above.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    thanks ian...
    Same here, been round in circles a few times, getting a little frustrating. when i changed them last time, didnt notice any corrosion, but ill give them another peek.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    If one fail, other light will act of 2 roles. Normally one on tailgate is sidelight, on side is sidelight and brake light in one. If one fails then either side overtakes the role.
  1. Brake light fault indicator.
    By Ste89 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 18:15
  2. brake light fault (confused)
    By frigosolver in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 15:34
  3. Brake Light fault
    By interceptor-jamie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 21:05
  4. strange brake light fault
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2010, 14:55
  5. rear light fault 2007 estate
    By ramsgate in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 19:01
