Thread: Cambelt and tensioner kit changed but not waterpump
    Jun 2012
    Default Cambelt and tensioner kit changed but not waterpump
    Hi At time of buying my 2004 Vectra 1.8 petrol a few weeks ago the dealer said they would replace the cambelt and tensioner kit. The car has done 70000 miles and owner who had it from new never had cambelt changed although regularly serviced (documented proof and verified) I know this was a disaster waiting to happen. I got my local garage who I trust to check if cambelt etc was replaced and it was. Not that i was suspicious lol However like an idiot I did not insist on water pump being changed and although not leaking or making any noises I am not sure what to do. (1) Should I get it replaced and as cambelt etc have only done 800 miles can they remain on car. How much labour time would it take to do water pump? or (2) If I leave it will the wate pump display and signs of bing on the way out thus giving me a heads up? Thanks in advance for your advise
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Depends on engine code
    If its Z18 XE I'd get it changed as these or the tensioners fail and snap the belt.
    If its Z18XER Pump is run off auxilliary drive belt
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    It will be the z18xe as the z18xer didn't come in until around the end of 2005 on the facelift model.
    To replace the water pump its likely to be around a 2 hour job, so including the pump around £120 from an independent, if you supply the pump. Still not seen a 1.8 with a failed timing belt or a failed water pump either on here, so I wouldn't get too excited.
    Jun 2012
    As DasArab says it is the z18xe. Water pump between £30 and £40 online so not too bad so probably spot on with £120 all in. Probably take your advice and not get too excited but may price it up and get some quotes. Just angry at myself for not mentioning water pump when they were going to change cambelt etc
  1. Cambelt change & waterpump
    By CHARLIE_VXR in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2012, 13:49
  2. cambelt kit and waterpump
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 19th June 2012, 20:30
  3. Cambelt and waterpump
    By Innocence in forum Engine & Drivetrain
    Last Post: 26th September 2011, 17:13
  4. Cambelt change; Is waterpump included at dealer?
    By NoMoCally:( in forum Engine & Drivetrain
    Last Post: 17th March 2011, 06:34
  5. Cambelt and Waterpump cost?
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2007, 15:41
