Thread: Fitting A Cr1 Box
    WAKEFIELD
    Default Fitting A Cr1 Box
    I know theres a how to thread on this site,but can i just ask a couple of questions
    Mines the 8 valve with the connection right under the engine.
    1. Found the common rail straight away got a screw driver down and pulled out the yellow tab,but still could not remove the connector do i still have to press something else to remove it or am i not pulling enough.
    2.I don't want to plug in the connector upside down like other people have done on this site causing warning lights to come on,but how do i know which way to fit it, seeing on a 8 valve you can't even see the connector.
    In other words which way is the right way up.
    Plus it's dark know so will continue tommorrow.
    http://www.vectra-c.com/forum/showthread.php?t=10676
    about the best on i can find at the moment...i'll post up anymore i find that are better.....
    WAKEFIELD
    Thanks for that,at least it's not just me struggling to get the plug off...Don't want to pull it too hard just incase i break something...
    Looks much easier on the 16valves.
    the access is much better on the 16V engine.. it's all on top....
    Here, there and every where!
    Here you go m8, Brocks did a very good "How 2" a couple of weeks ago.
    LINKY
    WAKEFIELD
    Yes i looked at that how 2 before i started,but when in the real world theres no space down there,it all as to be done by touch rather than looking at it,if you click the discusion thread Marky had the same problem as me...
    Will try again in the daylight.....that's if there is any tommorrow
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    You can climb up on the bumper and get ya head almost down the back of the engine.....I know I've still got engine oil on me best jeans!!!!
    WAKEFIELD
    I'm only five foot five i can only just see the engine compartment
    WAKEFIELD
    Did it at work today, much easier when someone shines a torch down there while you pull and fit the plugs..
    Regular Member The Doc's Avatar
    'Norf Yorks.
    How does it go?
  1. hid fitting
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:25
  2. USB fitting
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2010, 17:21
  3. When im fitting
    By PAULMAC77 in forum Styling
    Last Post: 3rd April 2009, 15:30
  4. fitting a PS2
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 09:30
