Thread: CDC 40 headunit/display safe
    Sep 2011
    Kent
    Default CDC 40 headunit/display safe
    Just fitted cdc 40 and it says headunit safe display safe. Other than. That and s pip when says headunit and display work. It was a headunit and display in one.
    Sep 2011
    Kent
    anyone, does this mean i need them tech 2 ? It only happens every 5 to 8 secs and everything works as it should.
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I do beleive it will need tech 2 fella has i had them divorced from my car i had it done by ***** in wolverhampton, it will show display safe because its not recognised by your cars security code all that needs to be done is tell the car the radio is meant to be there
    Sep 2011
    Kent
    cheers mate thanks, looks much better than the cd30 tho and sounds so much better
  1. getting around the display safe
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2011, 02:39
  2. Help with safe mode on my headunit
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2010, 16:51
  3. Display safe
    By ServerKing in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 06:05
  4. display safe !!??
    By bravocorsa in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2008, 15:10
  5. Display Safe
    By noseer in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2007, 16:22
vectra c cdc40 displaysafe
