Thread: Where to buy E20 carrier bolts
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Default Where to buy E20 carrier bolts
    Where can I get the replacement bolts for the caliper carrier chaps? I'm advised they "may" come with the discs but in my divvieness I havent checked yet. If not where can I get them and for how much?
    Thanks in advance
    Stuart
    11 Post(s)
    Just use the original ones. I spoke to 2 dealers prior to changing my discs and both said they don't bother replacing the bolts. They just clean up and remove the old stud lock from the threads and apply new stud lock on re-assembly.
    No new bolts came supplied with the discs I bought from Vx, btw.
    Jul 2009
    Perth, Scotland
    Ah ok Dave thanks for your input. need to source some thread lock now then
    Stuart
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Normally u can get them from Vx they around 1.30£ each they actually advice to change them every time u take them out , front ones are 230 nm torque rear ones 130nm torque
    Nottinghamshire
    The bolts don't come with Vx genuine disk/pad sets. Odd that dealers often don't have them as Vx say to replace them. Usually a 1 or 2 day order but this depends on the dealer. My own view is better safe than sorry for only around £5 per axle... Also, it's possible to damage the heads getting the present bolts out as the torques are high - especially on the front - and some people have found bolts that seem to be even tighter than they should be.
  1. caliper carrier bolts
    By maximus1267 in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2017, 16:39
  2. Caliper carrier bolts - still can't get them
    By shchuka in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2012, 14:45
  3. Where to get caliper carrier bolts?
    By shchuka in forum Suspension, Wheels & Brakes
    Last Post: 23rd September 2012, 22:01
  4. caliper carrier bolts
    By trickyjacks.4 in forum Handling & Braking
    Last Post: 19th August 2011, 16:48
  5. carrier bolts
    By Alerxt in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2009, 23:45
e20 bolts
e20 carrier bolt
