Thread: Pump timming on a 1.9 150
    Regular Member Mopar Man's Avatar
    herts
    Default Pump timming on a 1.9 150
    Does it really matter marking up the diesel pump pulley, when doing the cambelt? As the 120 doesnt even have a mark on the pulley. And its not a pulse pump.
    Just wonderd as i didnt take much notice, apart from the cam and crank lines on the belt. It feels down on power, but surley cant be down to this?
    Nope, only marks are the crank and cam pulleys mate. The pump is a constant output feeding the common rail at some ridiculous pressure, which is then used by the injectors when commanded by the ECU.
    herts
    Thanks. Just wonderd why they put a timming mark on the pump pulley?
    Generic pulley design...?
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    i think its 'Supposed' to go in a certain place but i have never timed them and have never seen them timed in a vx dealers and never had one problem
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    There is a timing mark so you can remove the pump pulley without removing the sprocket and timing belt
    Don't need to time it up with the cam adn crank pulleys tho.
  1. need timming belt changed anyone up for it??
    By rozzer2006 in forum West Scotland
    Last Post: 24th October 2012, 10:48
  2. do i replace timming belt? advice guys thanks
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 22nd October 2012, 10:45
  3. 150 cambelt timming marks please
    By Mopar Man in forum Diesel Engine related
    Last Post: 5th June 2012, 08:36
  4. away to pump 500L of heating oil with a 3.99 ebay drill pump.
    By TimTay in forum The 'Off Topic' room
    Last Post: 19th September 2011, 22:09
  5. looking for the timming marks for a vectra cdti 150
    By chrisgettings in forum Engine & Drivetrain
    Last Post: 25th March 2009, 21:55
