Thread: Airbag light
    Apr 2012
    Exclamation Airbag light
    Hi guys I have a 2005 (54) vectra life 1.8 and since owning it the airbag light has always stayed on, does anyone know the cause of this? And a possible fix? Also my mum has just bought a 1.6 09 Astra design that has also got the same problem but we know the drivers seat has been removed to have some stiching repaired in the past, checked the plugs underneath and they all seem to be plugged in, could this have the same problem? Any help will be appreciated! Thanks
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    If the seat in your mums car has been removed with the battery connected this will bring the airbag light on. It won't self cancel and will need a diagnostic session to turn it off. A variety of things can bring the airbag light on though. If you decide to come to one of the weekly north west meets then someone will be more than happy to run the diagnostics on it and see what's up.
    Apr 2012
    That sounds like a good idea, I did have a mate try and run the diagnostics on mine for the airbag but it wouldn't read it, where do I find out about the meets?
    Regular Member Lozza's Avatar
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    i had the same problem with my airbag light... came on one day, all the plugs under the seats were fine.
    was looking on ebay one and came across this
    http://www.ebay.co.uk/itm/VAUXHALL-V...item4a9c33a14e
    i had to strip the middle section out where the hand brake is and send off the airbag ECU to be reset
    took about 2days to come back,, plugged it and the light went out.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    If you scroll down the forum index to near the bottom you'll get to the regional areas. Here's a link to the next one. Tomorrow! Wednesday 13th. http://www.vectra-c.com/forum/showth...y-13th-June***
    We're normally there chatting away until they turn the car park lights off! I'll have some diagnostic tools with me too.
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  3. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  4. AirBag light
    Last Post: 9th May 2011, 18:28
  5. Airbag Light
    By Hollingsworth87 in forum Troubleshooting
    Last Post: 16th April 2011, 16:29
