Thread: Temperamental Central Locking
    Birmingham
    Default Temperamental Central Locking
    The central locking on my new car seems a little temperamental and also sometimes has a mind of its own.
    Sometimes it locks perfect with the flick of the remote button and also from the inside switch, then other times everytime I press the remote button it locks then immediately unlocks and keeps doing this, even from the interior lock button, then I have to lock each door manually and the drivers with the key.
    Can anyone help please?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Something I noticed in the way home, when the central locking plays up (unlocks it self automatically) the drivers side door open sign is illuminated on the dash.
    Add's up now. BUT whats the problem?
    Bye bye Vec B
    - Hello Siggy!
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Maybe a broken wire, or dodgy connection, between on of the doors. Try disconnecting each plug and give them a squirt with wd40 as a starting point.
    Birmingham
    Is that the main plug to the door? Ill do that shortly.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    WD40 didnt work!! However, when I disconnect the drivers door, the central locking works find and locks as it should!
    Where is the sensor on the door telling the system that it open or closed? The older cars used to have the little push in switch, cannot see one on this?
    Is that likely to be the problem?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    I did a check on it and this the trouble code coming up.
    Bye bye Vec B
    - Hello Siggy!
  1. Central Locking
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:27
  2. Central locking
    Last Post: 13th October 2009, 19:16
  3. central locking help !!!!!!!
    By VECKSZ in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 17:37
  4. Central Locking
    By S14RRJ in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2008, 01:04
  5. Central Locking
    By parapaul in forum General Chat
    Last Post: 18th October 2006, 20:48
