Thread: 12v ignition live for multiple items??
    Jun 2012
    Question 12v ignition live for multiple items??
    Hi, i am in the process of installing a new stereo :
    ( http://www.ebay.co.uk/itm/SILVER-Car...item3a6e480b4f )
    with a HD/SD DVB-T freeview box specific to that head unit.
    The freeview unit needs 12v power from the ignition not direct from the battery, it also has twin amplified antenna's which also need 12v power to each.
    I am also going to fit a dedicated ipone charger.
    I have read a few posts and was leaning towars using the 12v accessory socket but am not sure if wireing the freeview box, the 2 antenna's and the iphone charger would be too much?
    Any help would be greatly appreciated, Many thanks in advance, Shawzy
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    It's fine, I had all sorts running off mine in my Astra.
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Sawzy, I would lend towards running a 4-5mm core lead direct from a in line fuse at the battery, through the rubber gromit in the engine bay, behind the glove box and use a 4 pin relay switched from the supply to the cig lighter socket. As lee says, you should be fine but if a fault develops down the line, at least you'll know it isn't any of your 'extras' causing it. Best safe than smoldering fire wreck
    Jun 2012
    Thanks Lee for your quick reply
    Can you recomend a relay sierra, as i like the thought of the dedicated live from the battery?
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Please keep us posted on how you sort it and if the head unit and features are any good. I'm watching this on ebay at the moment and a little apprehensive about buying it until I hear feedback as I had a different one that wasn't very good
    Jun 2012
    Cheers for that Chaz, so, live from the bat with an inline fuse, through the bulkhead to the relay, switch wire from the accessory socket, Live out to the six way fuse box for a seperate fused feed for each accessory i want to add? is there any reason its showing a 5 pin relay or was that just as an example???
    Cheers again in advance Shawzy
    @ Pompey... Already have the head unit fitted and i already like it, couple of things need ironing out but as soon as i know the pro's and cons i'll make sure your the first to know...
    will add a few pics of in a seperate thread of the system when its fully installed
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    Spot on Shawzy. Just make sure the main fuse is close to the positive terminal on the bat, just to be safe.
    5 pin relays give you other options further down the line if you want to add or change things. Handy if you ever need/wanted a negative switched feed. Your talking penny's between 5/4 pin, or in the case of that Ebay seller, no price difference.
    Chaz
    11 Post(s)
    Quote Originally Posted by Shawzy View Post
    As long as the overall current being drawn is less than 10 amps then it'll be fine.
  1. No ignition live please help
    By foxyland in forum Vectra C / Signum Troubleshooting
    Last Post: 12th December 2012, 22:49
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Ignition live
    By dazza3674 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 20:46
  4. Ebay Multiple items..
    By Dwabo in forum General Chat
    Last Post: 2nd February 2008, 15:50
  5. ignition live
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2007, 20:03
