Thread: How much movement in tie rod
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    Default How much movement in tie rod
    I have a signum 3.2 v6 and changed the arb's today £5.35 from vauxhall bargain.
    While i was having a look about i wondered how much movement should there be in the tie rod as i can twist the osf one from side to side but no up or down movement
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    would be great if someone could respond I've done the front arb's and drop links but i think i can still hear a knocking when i go over bumps etc
    East Ayrshire
    Trim : SRI XP1
    You can rotate it clockwise/anticlockwise but you shouldnt be able to push it directly back/forth or up/down
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Really need someone to grasp wheel an 3&9 o'clock position an wobble it to feel for movement as being able to move it side to side their usually still ok.
    Have a look a strut tops. An wish bone bushes if still knocking.
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    cheers for the replies sounds expensive if its wish bone bushes
    Quote Originally Posted by david106
    Not really I just replaced both wishbones on my siggy , cost £80 for two
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    Thats sounds ok the noise is like a creaking sound happens more when i either turn into a fastish righthand bend or brake hard
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    Quote Originally Posted by marktaylor View Post
    was that for just the bushes or complete arms
    Complete arms , they were 39.99
    Each
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    Each
    where did you get them from do you have part numbers for euro car parts etc
    thanks
  1. no movement in temperature gauge
    By Dwing007 in forum Engine & Drivetrain
    Last Post: 27th January 2013, 23:54
  2. Front wheel movement
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2012, 17:13
  3. Odd Knock/Movement..........
    By Lean6 in forum Suspension, Wheels & Brakes
    Last Post: 22nd January 2012, 23:37
  4. Rear Suspension movement?
    By alcutler in forum Suspension, Wheels & Brakes
    Last Post: 28th December 2010, 14:02
  5. Steering wheel movement
    By kinger in forum Handling & Braking
    Last Post: 2nd August 2009, 18:11
