Results 1 to 10 of 11
Thread: Strange issue??
    Regular Member JamesGTB's Avatar
    Jul 2009
    Default Strange issue??
    Hi everyone
    Bit of a strange problem here but someone may be aware of it. When pulling up on the drive tonight the revs were up slightly and running generally a bit rough.My first thought was that it had started a regen but the MPG were as normal. I waited too see if the revs lowered but they didn't after 10 mins so I switched the engine off. When turning over the engine to start her again it was as if the battery was pretty much flat and she was extremely slow in turning over.the revs were normal but then climbed to around 1100 revs.I did notice that the swirl bar looks more loose than normal but it does move when revved. I can't quite see the connection between swirl bar and battery though. The battery is new this year and has been having slight drain after a couple of days but this problem today has completely thrown me. Help is greatly welcomed as can't use the wife's car as we have just had another baby and would like her to have use of her car in case of any emergencies.
    PRESTON
    Sounds like alternator, the car will increase revs if the alternator is failing to keep the car running. Check there is a min of 14 volts across the battery with the engine running.
    Jul 2009
    Thanks for the reply, that did briefly cross my mind so I will go and check it now if it starts
    Jul 2009
    Just checked the battery and she is only reading 11.6 volts so finger points to the alternator. These things must be made of cheese because it was new 3 years ago but last time it gave me the old spanner light.
    Many thanks for your help looks like my lunch break tomorrow has vanished
    PRESTON
    Is that reading of 11.6 volts with the engine running? If so it does look like alternator.
    Jul 2009
    Yes mate 11.6v when running. I will get a new one fitted tomorrow ~ if in the unlikely event it is not the alternator at least I have a spare to fit when it does eventually die ~ Which it will
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    the cdti has always had issues with the alternater the regulator normally goes in them
    http://www.vectra-c.com/forum/showth...lternator-gone!
    scottish region
    Exactly what mine done and was alternator
    Jul 2009
    Quote Originally Posted by DAVIDD88 View Post
    Thanks mate, the car was flat as a witches tit this morning so i was about to order a new alternator but have been told by the local motor factors that there are 6 different alternators and 4 amp ratings. 100A , 105A , 121A & 140A. Now I`m guessing that it is the 105A but cant see the rating on it as I`m at work and the car is at home. Can anyone give any clues otherwise I will just take a punt at the 105A. Car is a Estate 55 plate 1.9 CDTI 150 ps.
    Jul 2009
    [QUOTE=JamesGTB;1829630]
    Just called Vauxhall and they have told me its a 100A for my car, can i trust them as dont fancy ripping it out tonight to find i have the wrong one?
  1. strange braking issue...
    By hagga in forum Handling & Braking
    Last Post: 2nd April 2011, 19:39
  2. Strange issue with Central Locking
    By neilosmond in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2011, 09:17
  3. Strange ARB issue
    By jvr in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 17:52
  4. Strange stereo issue
    By Netstar in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2009, 08:08
  5. Strange 1.9 CDTi Issue
    By kryton01 in forum Engine & Drivetrain
    Last Post: 3rd December 2008, 21:24
