Results 1 to 10 of 14
Thread: CDTI 150 not well :(
    Edinburgh
    Default CDTI 150 not well :(
    So my Vec has been down on power recently. its like the turbo doesn't kick in til 2500rpm and before that its like a lame donkey. I thought it was EGR/inlet related (just glued my swirl flaps but that didn't fix it.) but i think its something else now but I don't know what.
    I recently pulled out a laybay in a bypass and booted it hard than I normally would to get up to speed (figured it might help clear some soot out). When I got to 3500rpm - 4000 rpm the power just disappeared and the car was suddenly even worse. After that I couldn't get the car to go above 3500rpm even with the clutch down and my foot down on the accelerator.
    I've also just changed the fuel filter to see if that wouldn't help and it doesn't appear to have.
    Anyone got any ideas? I'm in the process of trying to read the codes off it and will post back any I find.
    Engine : 1.9 CDTi
    Cleaned the boost sensor?
    Jul 2011
    UK
    Year : 06
    Vacuum hose split
    Edinburgh
    Quote Originally Posted by marc vectra sri
    Vacuum hose split
    Think we have a winner are vacuum hoses specific or can I get it from halfrauds?
    Jul 2011
    UK
    Year : 06
    eBay 4mm silicone hose cost ya couple quid
    Northampton
    Engine : A20DTH
    Mileage : 88000
    What colour is your number 3 injector plug? It should be blue
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by marc vectra sri View Post
    a few quid and an esay fix., If this ain't the problem well you've sorted a common fault before it strikes and it only cost a few quid.
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by merikiito
    They look pre 2007 plugs not the revised
    Northampton
    Engine : A20DTH
    Mileage : 88000
    thats what I thought but a lot of people only change no.3 which is out of shot in the picture
    Edinburgh
    Injector #4 is visible in the pic above. #3 is the new blue connector (replaced by me a couple of years ago.)
    Anyway, I replaced the vacuum hose and it's like a new car power kicks in around 1800rpm now and it feels like it should again. Thanks so much for your help guys especially marc vectra sri .
    I did break the nozzle off the vacuum sensor :s but I super glued it back on. Might need to replace it in the future if it doesn't hold.
    Thanks again
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  3. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
