Results 1 to 10 of 27
Thread: dpf removal, not the usual question
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default dpf removal, not the usual question
    it appears the new problem for me is the dpf is blocked, i guess with all the bad running and trying to start it i have blocked it.
    is it possible to by the bypass pipe thing to fit at home or is it possible to remove the dpf at home and then smash the insides out?
    how hard a job is it?
    Birmingham
    When my dad's car was playing up, the mechanic offered to cut it open and strip the insides out and then re-seal.
    Bye bye Vec B
    - Hello Siggy!
    Sep 2011
    Birmingham
    Trim : sri
    that's what i think i need to do, just wondered if its something to be attempted at home?
    once its running right i shall be getting the dpf and egr mapped out but need it running to do that!
    Engine : 1.9 CDTi
    If someone has Tech2 or type software they can do a manual/forced regen that will bring it low enough to do a proper/normal regen.
    Sep 2011
    Birmingham
    Trim : sri
    Quote Originally Posted by lee gsi View Post
    oic, in that case anyone have such a device and willing to come to my house to try it?
    PRESTON
    As i understand it, if you can get room to work under the car, then it's three bolts and a clamp, along with a hose or two and it's out. You can then use a long drill and smash the guts out of it. Don't forget, that until you have the regen software mapped out, if it does regen the smoke screen it will then create has to be seen to be believed.
    Sep 2011
    Birmingham
    Trim : sri
    ok thank you.
    i know it wont be perfect without the remap but as it stands i cant drive it anywhere to remap it even.
    plus there is nothing to lose by taking the insides out as i understand it. the smoke it would create would jsut be unburned diesel i guess as it tries to do a regen?
    the plan is o get it mapped with the egr and dpf deleted but as it stands i cant drive it so those options arent open to me
    Jan 2008
    I've got eactly the same problem with my vectra at the moment. I'm working out what to do with it. Let me know if you are sucessful removing the dpf.
    Sep 2011
    Birmingham
    Trim : sri
    will do.
    i am not 100% certain this is the issue but it seems a likely culprit imo.
    Birmingham
    I was in the garage to collect my car today and saw a DPF being drilled out of a 5-Series BMW. Cat was cut open and the insides were also being cleaned out!!
    Bye bye Vec B
    - Hello Siggy!
  1. not your usual HID question!
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2011, 23:27
  2. Front Spring Removal Question
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 01:46
  3. Cat removal question
    By Governor in forum Diesel Engine related
    Last Post: 12th December 2009, 18:28
  4. Restart INSP countdown - not the usual question
    By Ruperts Trooper in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 19:48
  5. Rear Badge removal done and Grille question
    By mikey68 in forum Styling
    Last Post: 3rd July 2008, 10:58
