Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: engine light 2.2 vectra 2003
    Dec 2011
    kettering
    Lightbulb engine light 2.2 vectra 2003
    morning
    my engine light came on my 2.2 petrol vec 2003
    the one on the right hand side of dashboard (not the spanner light)
    what could this indicate ,i have the equipment to check when i get home but im at work at the moment.
    there is no lack of power ,i just wondered if it was an emisions light like my old 2.6
    i will get the code later but any ideas would be a help
    cheers
    john
    Jan 2011
    Oxfordshire
    How many miles are on the engine? When was the timing chain last changed?
    If the chain is stretching (could be the old style oil nozzle which causes poor lubrication issues), this can cause an increase in emissions as it knocks your timing out slightly. This could in turn switch on the light you're seeing.
    Dec 2011
    kettering
    The miles are 74 k timing chain done 2006 no rattles from it
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by jpbroad1970 View Post
    Yes it is. The EML light normally just relates to things on the air intake, spark and exhaust side of things. It may just be something like a dodgy Lambda sensor or MAF.
    Dec 2011
    kettering
    thanks for that i will put on my code reader tonight and see what i come up with
    Dec 2011
    kettering
    i was stuck in traffic when it came on then drove 130 miles home without a problem
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    On my 2.2 direct my eml came on when I had a sticky thermostat. Does your temp gauge read correctly. Prob not this but worth a look.
    Dec 2011
    kettering
    Temp gauge all good sits half way no problem goes up a little then fan cuts in
    Dec 2011
    kettering
    i have took some live readings ,to me the front lamda sensor looks to be high compared to the other one
    it goes from about 70 about 900
    whereas the other one just goes up to about 180
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Did you read the actual codes?
  1. 2003 Vectra 2.2 DTI Engine Oil
    By AntSSSS in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2011, 18:39
  2. car and spanner light 2003 Vectra 2.0dti help
    By circushead in forum Engine & Drivetrain
    Last Post: 29th October 2010, 20:24
  3. 2003 ZC vectra: Horn, wipers, indicater and light problem
    By oz-tomm in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2008, 07:39
  4. 2.2 2003 Vectra Strange Warning Light Problem?
    By sophos9 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 13:16
