Thread: using carbon film and need to know how to remove a bit of the dashboard
    Regular Member Blurry120's Avatar
    Mar 2012
    Tameside
    6 Post(s)
    Trim : SRI, now with half leather!!
    Engine : 1.8 16v ZXE18
    Mileage : 106,000!
    Default using carbon film and need to know how to remove a bit of the dashboard
    i`ve doen the steering wheel and i`m damned if i know where the hell you get a torx screwdriver from for the tiny torx screws, any ideas? i`ve had to carbon film the controls as they are, any way i`ve also down the cigarette ashtray and lighter bits, and i`ve found you can remove the big long strip on the dash that runs along under the heater blowers and screen, thing is how do remove without damaging it?
    milton keynes
    long strip just pulls off , whats the issue?
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    The clips it sits on are pretty tight, the times I've removed it I generally start at one end, usually the end closest to the steering wheel, get your fingers behind the edge and pull towards you, is should pop free, support the next bit and again pull towards you, it'll get easier toward the end
    Mar 2012
    Tameside
    6 Post(s)
    Mileage : 106,000!
    Quote Originally Posted by kman247 View Post
    i`ve never done this before on a vectra, so hence the hesitation in wanting to break somethin,
    does anyone know any places to get the smal torx screw drivers from for the tiny torx screws that hold the steering wheel controls in the plastic
    Regular Member Greebo's Avatar
    Jan 2012
    In Limbo
    halfords http://www.halfords.com/webapp/wcs/s...egoryId_165572 this is the set i got one of these fits perfectly and you can use the smaller ones to dismantle the controls if needed.
    Mar 2012
    Tameside
    6 Post(s)
    Mileage : 106,000!
    cheers, i`ve managed to do the strip easy peasy to pull lol, i might have to do the steering wheel controls again tho as they`ll look better i think
  1. Replies: 4
    Last Post: 29th December 2012, 19:09
  2. carbon fibre film how to apply it?
    By mrk in forum Styling
    Last Post: 6th September 2012, 20:11
  3. Replies: 8
    Last Post: 20th August 2012, 08:09
  4. carbon fibre film
    By bobssignum in forum Styling
    Last Post: 12th October 2008, 13:37
