Results 1 to 10 of 22
Thread: Air on on the way out?
    Regular Member GoldenWonder's Avatar
    Durham
    Default Air on on the way out?
    Well after having my air on regassed twice it's now making loads of whirring and whooshing noise when it's on. The air comes out cold but you can hear a mechanical whirring that increased with engine speed and various whooshing and 'air gurgling' noise inside the car.
    I assume it's the compressor on the way out? It's got warranty still but I doubt it's covered. Looking at compressors on eBay there not cheap!
    6 Post(s)
    Quote Originally Posted by GoldenWonder View Post
    Have you got a policy book of what's covered and what's exempt from the cover?
    I would have thought it would be covered.
    Regular Member amand's Avatar
    Feb 2011
    west London
    i have the same problem. well my air con gas has just leaked again. i dont know if the compressor is on its way out but i get those noises as well.
    Durham
    Its a typical warranty booklet - it lists exclusions (and the aircon system isn't mentioned at all!) but then states the list isn't a total list of exlcusions.
    I guess I'll have to book it in and see, its getting noisier!
    Durham
    Just been told its leaking around the evaporator. Sounds like a major job - dashboard off by the sound of it?
    Has anyone had this done on their Vec? Garage reckon they will need the car for a week to do it!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    http://www.autoairconparts.co.uk/vau...tors-and-more/
    price list i found but i know you have a warranty
    Durham
    Ouch! And with fitting taking all week this is a major bill. Looks like no aircon for me for a while
    New Member a wet monk's Avatar
    Newcastle-under-Lyme
    I wouldn't know much about the workings - mine's starting to make the noise described above, but I did the coward thing and turned up the tunes!
    Durham
    Well the noise only lasted a week or so before the aircon packed up again.
    Regular Member Signumv6man's Avatar
    Suffolk
    Trim : Elite Auto
    Engine : 2.8 V6 Turbo
    Eek Sorry to hear about A/C problem
    Fellas,
    My aircon compressor started making a noise (mechanical whirring), got worse over a couple of weeks. Had it re-gassed, quiet again for a week, then noise back twice as bad.
    Shortly after that it stopped cooling and at tickover the compressor started sounding like a box of nails being shaken.
    A little diagnostics with a friend/local independant specialist revealed that the compressor had failed, and when we removed the bumper to change it several patches of dye (mixed in with the oil/refrigerant to enable leaks to be detected) were clearly visible on the condenser finning. The condenser was perforated in at least 3 places.
    Once condenser and compressor replaced and whole system re-gassed and oiled, all is well - almost completely silent operation and on cooling the icy blast coming from the vents inside is lovely on a hot day - problem fixed.
    But:
    Compressor supply only £488 plus VAT
    Condenser supply only £263 plus VAT
    Will leave labour and fitting to your imagination but even doing half the work myself didn't leave much change out of £1k (no pocket money for me for at least the next year !!!!).
    Good luck,
    Signumv6man
