Thread: spanner lights on the dash of my vectra c facelift 1.9 cdti 120
    Jun 2012
    st austell
    Default spanner lights on the dash of my vectra c facelift 1.9 cdti 120
    hi every one i brought my car about 2 months ago and for the first 3 days it was fine then out of no where the car went into limp mode (spanner light came on) and scince then all i have had is problems i can not go above 2000rpm-3000rmp it will go into limp mode. it smokes very bad, i am running out of ideas i have put a new air mass on and new egr valve and gaskets set,
    thanks in advance dan
    11 Post(s)
    Needs the fault code(s) reading out.
    Not sure if the pedal trick works on your engine - the info is in the how2
    Jun 2012
    st austell
    hi i have had the car plugged in twice and it shows no fault codes, but it does remove something, i also could not find the link to the pedel trick cheers dan
    11 Post(s)
    Quote Originally Posted by danielle7906 View Post
    http://www.vectra-c.com/forum/showth...-any-Equipment
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    Have you checked the vacuum boost pipes? RHS of the engine at the front, next to the battery the pipe goes back to the metal piped over the top of the engine. The hoses are notoriously bad for splitting, particularlyat the 90degree bend, do a search for vacuum booct pipes on here and you'll find LOTS of info. Cheap fix at about £5 for a length of 4mm ID silicone hose.
  1. Yellow oil can on dash. 1.9 cdti 150 Vectra
    By Hover80 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2010, 21:15
  2. Dash Light Problem Vectra Facelift
    By holden77 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 15:46
  3. 03 vectra 2.2 dti auto spanner lights
    By newtovectra in forum Engine & Drivetrain
    Last Post: 29th April 2009, 22:54
  4. Vectra CDTI Spanner Light-2004
    By Vaux-Man-G in forum Vectra C / Signum Troubleshooting
    Last Post: 20th May 2008, 15:21
  5. How Do I Fix My Vectra Dash Lights?
    By Madmarky01 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2008, 09:37
vectra c facelift car and spanner light
