Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: 2.2 direct misfire
    Mar 2012
    Walsall
    Default 2.2 direct misfire
    i have 56 Signum with the 2.2 direct engine. on the way home from birmingham this afternoon the car started to feel a bit flat before eventually the car started to slow even under full throttle. Limp home mode activates so i pull it over. it ran fine on idle, but was misfiring all the way up to 3k. **** about with it for a few minutes making sure everything is connected, turn it off and the Limp home mode goes away.
    Pull off and it starts misfiring horrifically, resulting in no power at all. was misfiring on idle too. get it home and read the codes and it throws up a p0302 - misfire on cylinder 2. leave the car for 5 mins, start it up and its smooth as you like on idle, will rev upto 4 with no issues, but as soon as its under load it misfires.
    reading through the threads i see that the general concensus on these is HPFP, but this was replaced not long ago under waaranty and is a CONTINENTAL. not Siemens. FPR was done at the same time also.
    so, ideas? Coilpack? sparkies? swirl flaps? voodoo?
    i'm a diesel head myself, so this petrol malarky is all voodoo to me..
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    check your coil pack, seen photos on here the other day where someone had a miss fire and his contacts on the coil pack was cracked, HTH
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    If it was the fueling i.e HPFP FPR it would throw up the p0191 (I think lol) code and not a misfire fault code....I suggest maybe coilpack/plugs......take plugs out clean up and stick back in.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    Mar 2012
    Walsall
    oh and the EML light is on too.. the spanner has gone
    Mar 2012
    Walsall
    coil pack off, no cracks, but cant see the contacts as they are ****ty springs?
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    How about swapping coil pack with another one and seeing if the same fault occurs on the cylinder with the suspect coil-pack now on it?
    Mar 2012
    Walsall
    i'm the only person i know with a 2.2 direct.. and i'm not buying one on the off chance..
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i would go for fpr or fuel pump my self i have sin wired codes caused buy the pump
    Mar 2012
    Walsall
    Quote Originally Posted by paulvectrac View Post
    but there are no pressure related codes being thrown up?
  1. 2.2 direct misfire madness
    By Mattyface in forum Vectra C / Signum Troubleshooting
    Last Post: 13th August 2012, 21:10
  2. 2.2 Direct Misfire Problems :(
    By jonny180 in forum Engine & Drivetrain
    Last Post: 14th April 2012, 20:00
  3. 2.2 Direct 54 misfire sometimes
    By rodzynx in forum Engine & Drivetrain
    Last Post: 4th March 2012, 12:22
  4. 2.2 direct judder / misfire
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2009, 13:12
  5. Z22YH (2.2 Direct) Misfire
    By johnmac in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:31
vectra 2.2 direct p0191
vauxhall vectra 2.2 direct misfiring
Opel Fuel Pressure Regulator 2.2 Z22YH
