Results 1 to 10 of 24
Thread: Any mechanics with knowledge of the VVt
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    10 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    Default Any mechanics with knowledge of the VVt
    Hi all if theres anyone on here with experiance of working on the 1.8vvt engine please speak up lol i would like to pick your brains cheers
    Mar 2012
    liverpool
    10 Post(s)
    Trim : VXR
    Mileage : 44,000
    anyone??
    Regular Member Greebo's Avatar
    Jan 2012
    In Limbo
    it helps if you have specific questions to ask people
    Mar 2012
    liverpool
    10 Post(s)
    Trim : VXR
    Mileage : 44,000
    i was just hoing to ask has anyone repaired a vvt unit that had knocking from top and what it turned out to b
    Jul 2011
    edinburgh
    The VVT unit can make a light tapping noise when cold which is normal. But if it makes a loud rattle / tapping noise for about 2-6 seconds on start up but then goes away, the solution is to take off the filters/gauze from both the VVT actuators.
    Easy job to do, but it will cure ONLY the loud 2-6 second rattle as the blocked gauze/filters starve the top end of oil.
    Hope this helps your query
    Mar 2012
    liverpool
    10 Post(s)
    Trim : VXR
    Mileage : 44,000
    hi boxman what i have is a loud constant knocking on idle ALL the time since i had an oil leak and car did run rather low when wife took it out
    Jul 2011
    edinburgh
    That does not sound right at all. Is the knocking coming from the top of the engine?- I guess it is filled to the correct oil level now? But that noise sounds like a serious oil starvation at the top end. Have you run the car at normal speed / revs this would normally get the oil flowing around the top end? Does the oil pressure light go out after a few secs after starting the car up?
    If all above is "yes" I'm not sure what it could be, I'm no expert on VVT specifics and my 58 VVT does tap a bit at cold idle but goes when egine is warm - heres hoping it is not more serious -I will have a think of other things it could be -
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it defiantly a top end knock?
    Guy that works on ramp next to me. Has experience on vvti engine I can ask him.
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    The VVT Can knock all the time if permanent damage is done.
    There is some videos on YouTube about this in fact. The Cams get starved of oil, and it knocks on startup. This gets progressively worse until it's there all the time.... and then the internals give up.
    Firstly remove the Cam Pulley top cover (2 bolts) fire up the engine and verify if the knocking is from there. It could be some thing else of course, but if it's the VVT System then thats is where the noise will be from.
    It sounds to me like the pulleys are stuffed but I could be wrong. The VVT mechanism runs on oil pressure and without it, it does knock. But she shouldn't knock all the time. it'll go away after 1-2 seconds from cold start followed by the oil light a couple of seconds later.
    Matt
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    good info there matt his mechanic has mentioned it may be the pulley
  1. HID knowledge required
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 11:08
  2. May already be common knowledge
    By Critch in forum Engine & Drivetrain
    Last Post: 14th December 2012, 20:06
  3. Hid kit knowledge please
    By anthonychall in forum Styling
    Last Post: 4th November 2010, 19:01
  4. Calling all mechanics! Knowledge needed!
    By Giw in forum Engine & Drivetrain
    Last Post: 11th June 2010, 09:01
  5. Anyone Have any Knowledge of this...
    By chrisschild in forum General Chat
    Last Post: 3rd July 2008, 18:31
