Results 1 to 3 of 3
Thread: Car with spanner on when uphill or downhill??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Car with spanner on when uphill or downhill??
    S above. I don't get car with spanner anymore apart from going uphill or downhill, after it comes on, about 2 minutes or less depending on ldvel of road it goes out and I gain power back again.
    Why is this? So I can recify the problem please. No guessing, just need straight answer please
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by Humourbash View Post
    Thanks[/QUOTE]
    Check your boost pipe work (IE inter-cooler pipes etc). When your car is under boost those pipe's will expand under pressure opening up any small splits or holes in the pipe. This would be my diagnosis/guess going off your symptoms and not being able to see the car.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I was worried it might be that :-/ have to dismantle the front 4th time and see if I can find any problem hose. How can we check as if under pressure as u said, expands and it'll open the split. Can we manually do this without pressure?
  1. Loss of Power when going uphill
    By DonDedders in forum Engine & Drivetrain
    Last Post: 27th August 2014, 12:21
  2. 1.9CDTI 120 - Stalling on mways uphill...
    By RichieClyde in forum Engine & Drivetrain
    Last Post: 30th August 2013, 21:51
  3. stuttering uphill
    By ALD in forum Engine & Drivetrain
    Last Post: 11th April 2011, 12:53
  4. All downhill from here...
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 14:34
  5. Uphill Race
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2007, 09:49
